Old 05-15-2010, 10:23 PM   #1
Ex-Driver
Drives: Silver H/B Yaris
Hello, Shake while accelerating with 07 yaris.
i checked my spark plug, all of them are in good shape, no wear, clog or rust on it. i have 145xxxkm on it. I found out that my Idle is pretty low. it's above 500 rpm, i was told that it should be 700 rpm or 800 rpm. If that's the case.. it's the alternator problem. Or maybe the ECU is receiving wrong message from electric system.
Oil change was done 2 weeks ago.
replaced oil filter as well.
I'm currently going through that shake while accelerating right now.
Does anyone else have this problem and got it fix??
Any help would be appreciated
Originally Posted by adigilani View Post
Hi All
I have bought a second hand Toyota Yaris Registered in 2000 in Ireland. This is first time i have a toyota VVTI engine and just trying to understand all. I have few question and was hoping if someone can answer.
1) when i start the engine (car is parked unused couple of hours) the hot coolant sign (red) comes on but turn to cold coolant sign (green sign) instantly and stayes for a while and then disappear. It doesn't go back to red or green. Is it normal? If not, should i replace the coolant. If yes then how i can do that.
2) Car is shaking a little bit and when i press the accelerator car misses sometimes and i think i am not getting the full power of the engine. What can be the reason. I had a renault clio and it did the same thing and i discovered the ignition coils are gone. When i bought the car i was told the car is serviced and i checked the oil and it doesn't look like it need replacement. The mileage is only 32000miles. The service light doesn't come also so i guess it doesn't need service.
Can someone please answer the question.
Any help will be appreciated.
Ex-Driver is offline   Reply With Quote
Old 05-18-2010, 10:14 PM   #2
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
If it is a 1.3 or 1.5 litre petrol motor, then the correct hot idle speed with out any accessories on (a/c etc) is 650 rpm.
rob323 is offline   Reply With Quote
Old 05-19-2010, 06:34 AM   #3
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
ok recheck the plugs the plug wires could be loose and not making contact properly, if they are fine, check your fuel filter, also there could be dirt in the tank as the miles are high, also does the plugs have plug wire or does it have a box on the end, if it has box at the end, one of those boxes are not working, this happened to me with my bmw, and there is no power, and when the power comes it comes, let me know if you come right,
www.justbabynappies.co.za
nazier is offline   Reply With Quote
Old 05-19-2010, 06:51 AM   #4
Kongo-Otto
Drives: '09 Yaris & '10 Auris
Just install the new plus as they come out of the box.
Never use copper paste for spark plugs or any part made from aluminium like cylinder heads. Copper paste is conducting so keep it away from high voltage (or even low voltage) parts. Copper paste will boost corrosion of aluminium (cylinder heads).
This MAY work and you MAY not have any problem but its for sure not recommended. In general you don't have to use any antiseize on spark plugs but if you really think you have to use it ... try other products like ceramic-based anti-seize.
Old 05-19-2010, 06:56 AM   #5
nazier
black shark
nazier's Avatar
thanks for that advise will keep it in mind,
Tags
2000, coolant, engine, shaking, yaris
