#2 | |
Half a Bubble Off Plumb
Another reason mileage may go down is if you get gas of lower octane and the knock sensor tells the ECU to retard the ignition timing. That reduces efficiency. Anybody who's interested in acquiring a fuel alcohol test kit should browse go-kart racing sites. |
#3 | |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
That makes sense, but QT has big labels on all the pumps stating the "up to 10% ethanol" so I dont think its that, not sure, but I also dont argue with success,lol. They are real good about jumping into any gas war too so the prices are as low or lower most of the time.
So does everyone else have those "up to 10% ethanol" labels.
#7 | |
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
The main benefit to E10 is that it makes injector cleaners a thing of the past (they might even damage the injectors if they're already clean! )Main drawback, is of course, the slightly lower gas mileage. Depending on how many cold starts I'm doing, I'm averaging 35-36 MPG in the city, 40'ish MPG on pure highway (4dr. LB auto). Lately I've been doing these two mile jaunts to work, shut it down for a few days, come back from work, two mile jaunt, etc. I'm looking at the gas-gauge and I know the MPG is gonna be hurtin'. On the flipside, I'm down to half a tank, but my last fill-up was on July 9th. |
#8 | |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
Cheers!
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
![]() Drives: Caddie cts, Dodge ram 1500 Join Date: Jan 2011
Doesn't it take the same amount of energy to accelerate the car from 0 to 60 or whatever no matter how fast or slow that acceleration happens? And aren't motors a little more efficient in the rpm range where the torque is highest? And finally, isn't your top efficiency at the lowest speed where you can be in your highest gear? So....wouldn't relatively quick acceleration up to 40mph or wherever you drop into 4th or 5th (depending) be the best? I've heard 3/4 ths of the throttle mentioned before.
What's your take on this? Joe |
#10 | |
With the help of SGII
Drives: 2009 Yaris Sedan Manual Join Date: May 2010
What if you could get the same gas, but not get the crappy ethanol? OH wait!! You can! lol Check out this site.... The stations that sell straight gas are starting to pop up around the country again, and i cant wait to see what it does to my mpg's! http://pure-gas.org/index.jsp |
#11 | |
"Pure" gasoline hasn't been around for a lot longer than the ~4 years since E10 became the standard. Before that, most gasoline sold in the U.S. had ~15% methyl t-butyl ether (MTBE) in it. There are a number of other oxygenates that were used, like TAME (t-amyl methyl ether), diisopropyl ether, isopropyl alcohol, t-butyl alcohol, methanol, etc. The market for them has really been hit hard by the mandates pushed through by the ethanol lobby. If you get the raw gasoline pumped through the pipelines before it's had the oxygenates added, you'll get something that's about 2-4 octane numbers lower than the ethanol blended stuff. That will make your engine retard its spark timing and run less efficiently. There's a lot to criticize about growing corn to make motor fuel out of. But the "true believers" in the harmful effects of fuel ethanol are pretty much deluded. |
#12 | |
"LibertyRides!"
From changing over to this gas there has been around 3-5% increase in my MPG's. Cheers!
Most of them, I believe, I know the one I filled up this weekend did. Ive always heard ethanol would hurt mileage, and maybe ,as you all have said, there are other contributing factors.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
We've been averaging 39 miles for both automatic YARIS as of lately . The warmer the weather the better the mileage . Tires set at 35 > 36 p.s.i..
#15 |
must be nice .
#16 |
![]() Drives: 2010 Toyota Yaris 3 door Join Date: Mar 2010
I average 35 MPG with an automatic.
#17 |
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
i've gone through 4 tanks now in my new (to me) 07 sedan with automatic transmission. my average so far is 38.43 mpg.
#18 | |
| Tags |
| automatic, manual, mpg |
| Automatic to Manual converts... any regrets?? | maramaralula | New YARIS Purchase Forum | 22 | 07-31-2011 11:06 AM |
| Is LSD Automatic & Manual Same? | maxgil05 | Performance Modifications | 4 | 04-24-2009 11:57 AM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 05:25 PM |
| Change automatic to Manual | Blenjar | General Yaris / Vitz Discussion | 11 | 06-14-2007 07:02 AM |
| Manual vs. Automatic ?? | YarisBlazer | General Yaris / Vitz Discussion | 12 | 08-13-2006 08:14 PM |
