Old 06-16-2010, 01:27 AM   #1
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Originally Posted by jhsouders View Post
Seeing as this came up, as you know ethanol reduces fuel efficiency, so up to 10% ethanol can hurt your mileage by around 10%.
No, it doesn't equate to that at all. E10 gasoline has about 3.4% less energy per gallon than "pure" gasoline. That's about how much your mileage will drop.
"Pure" gasoline hasn't been around for a lot longer than the ~4 years since E10 became the standard. Before that, most gasoline sold in the U.S. had ~15% methyl t-butyl ether (MTBE) in it. There are a number of other oxygenates that were used, like TAME (t-amyl methyl ether), diisopropyl ether, isopropyl alcohol, t-butyl alcohol, methanol, etc. The market for them has really been hit hard by the mandates pushed through by the ethanol lobby. If you get the raw gasoline pumped through the pipelines before it's had the oxygenates added, you'll get something that's about 2-4 octane numbers lower than the ethanol blended stuff. That will make your engine retard its spark timing and run less efficiently.
There's a lot to criticize about growing corn to make motor fuel out of. But the "true believers" in the harmful effects of fuel ethanol are pretty much deluded.
Old 06-16-2010, 09:53 AM   #2
STC
"LibertyRides!"
STC's Avatar
Yes... pure gas is called RBOB Gasoline. It is oxygenated gas that uses different additives than ethanol. This is only what I use. Two mom/pop gas stations and one premium Shell station that sell this non-ethanol gas are left in my area. Only difference is when you buy Shell gas you get their proprietary detergents that they say helps clean your engine... 'Premium pure gas'.
From changing over to this gas there has been around 3-5% increase in my MPG's.
Cheers!
~ Mark ~
automatic, manual, mpg
Automatic to Manual converts... any regrets?? maramaralula New YARIS Purchase Forum 22 07-31-2011 11:06 AM
Is LSD Automatic & Manual Same? maxgil05 Performance Modifications 4 04-24-2009 11:57 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 05:25 PM
Change automatic to Manual Blenjar General Yaris / Vitz Discussion 11 06-14-2007 07:02 AM
Manual vs. Automatic ?? YarisBlazer General Yaris / Vitz Discussion 12 08-13-2006 08:14 PM
