Old 05-28-2010, 08:52 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
I put a new water pump on and short serp belt and went for a test drive. Sure enough the idle was racing to 4k when I came to a stop. Just by chance I turned off the fan for the defroster and the idle went to normal. I played with it and sure enough the whole idle issue was fixed by turning off the fan. That little bit of voltage drop from a tired battery was getting a dramatic reaction from the ECU.
Now its fine . I ordered a battery and assume that will fix the fan problem.
I got 170K out of the original battery. My scan gauge always showed a good voltage but I think its wrong. If I had known I would have replaced it a while back.
yaris9876 is offline   Reply With Quote
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
timing sound when car is under load aucorium Yaris TS Talk 2 08-28-2011 01:59 PM
replacing timing gear full yaris9876 DIY / Maintenance / Service 1 05-09-2010 10:49 PM
CAM TIMING jt258 Performance Modifications 21 11-12-2009 12:50 PM
australian vs american models: timing chain hoobyjuice DIY / Maintenance / Service 3 06-16-2009 09:25 AM
