#19 |
Modded Moderator
ah, lol.
#20 |
#21 |
Modded Moderator
I might, no inspections where I live.
The hose came off again, resulting in poor idle and a CEL. Going to trim the coupler tomorrow. |
#22 |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
So, am I to understand, with the Corolla 1ZZ TB, you can just toss that on in place of the 1NZ TB with no further modifications? Or is it a good idea to have a better header on there first? I'm going to a salvage yard this week or next and would like to see if I can track one down if that's the case.
#23 |
toyota
im curious what happen next on astros tb..
#24 | |
#25 |
Modded Moderator
From what I've read here, it seems to be the TB with the US part no., the japanese part seems to work better.
On a interesting note, my '05 corolla TB I purchased from Functionspec had a odd part number (#22030-0D030). There was a thread on here on how to do it but the OP deleted his posts. http://www.yarisworld.com/forums/showthread.php?t=14672 So far the only time the car runs like crap at low RPM and throws a CEL seems to be when one of the hoses that hooks up to my intake falls off because the new coupler is almost an inch longer than the stock one. I'm going to trim it down today which should get rid of the problem. If I can find my digital camera I'll take a movie of just how it sounds, as it changed a LOT. Sounds really really good now, and I'm still stock after the header. I haven't done the chip swap or adjusted the idle, will give it some time as the TB was only installed yesterday. |
#26 |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
I love to see a dyno sheet from a YW member that shows any improvement with a larger TB on this car with stock cams, inlet manifold and head. Laws of physics say NO improvement is to be had. And I mean back to back, same temps and fuel. Some days my car makes what feels like 10 more hp than other days - usually due to barometric pressure and temps, so you will alway have that variability in the mix. AGAin the power is ALL TO BE HAD in the cam phasing (vvti) with stock cams, ONCE YOU UNCORK THE EXHAUST AND HAVE A GOOD cai. yES i AM A DOUBTER.
#27 |
supossedly Yoda? has a dyno that shows 3whp improvement, i think. however, that dyno was probably done on a different day with different weather conditions. so who really knows? hehe
edit: post #11 of this thread.. |
#28 |
my run was not on the same day. i am going catless next week so i will put that dyno up. hoping for 120whp
#29 |
scrap that. just took a ride in a honda fit with a straight pipe from the header back.. it smells and sounds really bad. just gonna put that money towards something else.
#30 |
I've unplugged the VVT-i solenoid before just to see how the car went. It was night and day. WAY more consistent power and probably a few more up top.
(Unplugging the VVT-i solenoid retards the intake cam to 0° all the time) |
#31 | |
Why don't you do what barber did? |
#32 | |
#33 |
Modded Moderator
150 miles and the car purrs, no CEL. It's amazing what a difference this has made in how well the car pulls now when accelerating, I'm not having to push the pedal down as much to go uphill, and passing is much quicker. REALLY can't wait to get the custom exhaust done. I've done a TB swap before, this one really shines. Even my mechanic is impressed with how well the car responds and accelerates now. Do this mod, it's well worth it!
#34 |
Yes, if you can get it to work.
#35 | |
![]() ![]() Drives: Toyota Join Date: Mar 2010
Astroman, did you swap the chip? |
#36 |
| Viper Alarm Install | gwasabi | In Car Entertainment + Electronics (audio / video / alarm) | 28 | 08-11-2010 02:57 PM |
| Idea I had, but I can't figure a way to make it work... | kac | Cosmetic Modifications (Exterior/Interior) | 4 | 08-08-2009 09:17 PM |
| YarisWorld Marketing Idea | *MAD DOG* | General Yaris / Vitz Discussion | 30 | 04-12-2009 05:46 AM |
| High pitched whine using stock head unit / aux input? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 02-02-2007 12:49 PM |
