Old 06-07-2010, 06:11 PM   #1
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
Originally Posted by bkrownd View Post
This is the way speedometers are designed. They typically read 3% or more faster than the true speed.
And there is an allowable tolerance of error during manufacture. Federal law is +/- 10% for Speedometers I believe. Most car makers keep it a lot closer to nominal. Some will read spot on and other will read a little high. It's really rare to find a stock car that has a speedo that reads slow. The requirements were set up around the old cable driven speedometers and have never been updated to line up with today's more accurate systems.
On a side note, there was some speculation a few years ago that car makers were manufacturing the speedometers and the related hardware so that it always read faster than what the car was going. This runs the warranty out quicker and before the car hits high enough actual miles to end the warranty. For example, if your speedo reads 5% higher than actual speed then your Odometer is also reading the miles 5% faster. On a car with a 36,000 mile warranty, at 5%, the car has only actually traveled 34,200 miles when the Odometer reads 36,000 (OP's post indicates around a 4.5% variance so he has approximately a 34,400 mile warranty). Obviously, the higher the mileage limit on a warranty, and the bigger the variation form true speed, the more beneficial it is to the manufacturer to have the speedo read higher than actual speeds and register miles faster than it should.
Stove is offline   Reply With Quote
Old 06-07-2010, 06:47 PM   #2
bkrownd
bkrownd's Avatar
Drives: 2010 Yaris "5-door"
That isn't necessarily true. The speedometer needle could easily have an offset that makes it different from both the odometer and reality. (It's possible the offset is smaller and/or more linear than in the old days, though.)
bkrownd is offline   Reply With Quote
speedometer lights pEAchEzpwnz DIY / Maintenance / Service 8 04-20-2020 09:02 PM
09 Sedan Speedometer with Tach MT Low Miles. A1phazu1u Items for Sale by private party 17 05-13-2010 05:08 AM
speedometer from TS in terra mk1 tiger Cosmetic Modifications (Exterior/Interior) 0 09-02-2009 01:15 PM
No speedometer or tachometer lights during day cdavidhess DIY / Maintenance / Service 20 06-30-2009 10:38 AM
Speedometer Trouble jonathancash DIY / Maintenance / Service 7 05-12-2009 03:04 AM
