Old 05-11-2009, 03:22 PM   #1
jonathancash
Drives: Toyota Yaris/Vitz 2007 (Jap)
Question Speedometer Trouble
Hey Guys,
New to the forum - First post actually - Having some speedometer trouble with my yaris. I took apart the instrument panel to clean it out and just happened to move the needles about gently and barely even so.
Now whenever I start the car the needle drops to below 0 almost as if its -5 or -7 kmph. I've reset the needle while the car's been both on and off. Eventually the needle always sticks back down to its sub-zero position. Almost as if though it resets after every 30 seconds or so once the car's been shut off.
I've been searching the forums for DIY posts etc. and one mentioned that the needles recalibrate automatically but mine hasn't yet. How do I fix this? Would I need to remove my needle and reposition it? That's the only thing I haven't tried. Or is there another way.
Any help would be appreciated.
jonathancash is offline   Reply With Quote
Old 05-11-2009, 04:55 PM   #2
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Possibly the needle is a little loose on the actual motor what did you use to clean it? If the adhesive holding the needle was weak it may have ate it so the motor is turning but the needle isnt going with it.
Old 05-11-2009, 04:56 PM   #3
PHXDEMON
PHXDEMON's Avatar
Also just to clarify does it reset to its original postion once the car is turned off or does it stay at the bottom below zero?
Old 05-11-2009, 05:03 PM   #4
jonathancash
Oh it's just fine whilst driving. If say I reset the position of the needle to point at 0 - it stays there, I'll drive around fine and it'll move all the way up to 120 if it has to. It'll fall down to 0 and stay right where its supposed to stay as well when the car's in parking.
Now when I switch off the engine and leave the car off for about a minute - then put the key into the ignition and switch it on - the needle's back down at sub zero. So it doesn't retain the adjusted position, just goes all the way down. Which means I have to then pry open everything and readjust all over again.
When I opened up the HUD for cleaning I didn't use any solvent etc. just a plain dry cloth - gently went over the dial and the surface.
Old 05-11-2009, 05:08 PM   #5
jonathancash
Also I haven't tried removing the needle or anything yet. I was thinking that maybe if I set the needle to say 20 kmph - above the zero mark - switch off the engine and then leave it for about a minute it could drop to 0 instead of sub zero.
I don't know really, I'm just thinking off the top of my head here. I don't want to fiddle with it too much just incase the needle stops moving altogther.
Old 05-11-2009, 05:15 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
it's a stepper motor that drives the needle, it just needs to be reset. try removing the needle, go for a drive, shut off the car, turn the ignition back on and put the needle back on at "0"
Old 05-11-2009, 05:17 PM   #7
jonathancash
I think I'll try that first thing tomorrow morning and see if it works! Thanks
Old 05-12-2009, 03:04 AM   #8
jonathancash
That worked perfectly, thanks Guys!
instrument, needle, panel, speedometer
Trouble Code P2121 1nz DIY / Maintenance / Service 9 09-02-2024 07:59 AM
Speedometer Error? MadMax General Yaris / Vitz Discussion 18 02-27-2009 07:22 PM
Changing out the stock speedometer and getting a digital daf62757 Fuel Economy Forum 2 02-20-2009 11:21 PM
YarisGarage trouble? ChinoCharles Suggestions - Feedback - Questions 7 08-16-2007 04:48 AM
Having Trouble with TWM Short Shift Install. Need Help xfatefailsx07 Performance Modifications 3 10-10-2006 01:38 AM
