Old 06-09-2010, 11:02 AM   #1
Originally Posted by jonimac View Post
Hi to all... just a noob here in M.E., just wondering if I tap the leads (+,-) of an LED light to the pink n blue from that pic above, will the new led light acts the same as the dome light? will the new led light dim to off as well upon turning off the ignition? Or just turns on when the doors were open? Sorry to much question. Need help where I can tap my led lights so that it behaves the same like the dome light, using its switch also to turn on my led lights underneath. Thanks so much. -jon
If you tap the pink and blue, the LEDs will behave the same as them dome lights, provided that you leave the dome light switch in the "Door" position. If you manually switch the dome to "On", with the doors closed, the LEDs won't light up with the dome.
Old 06-09-2010, 04:56 PM   #2
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
Thanks CTScott... got the idea!
jonimac is offline   Reply With Quote
Old 03-19-2011, 07:44 AM   #3
iicaie
Drives: Vios E
Hi, how do you suggest wiring LEDs so that they behave exactly like the dome light does? ie. turn on when doors open, switch to ON - light up with dome light. thanks
iicaie is offline   Reply With Quote
Old 03-19-2011, 09:50 AM   #4
The only way to make them function exactly the same as the dome, including the switched on mode is to run the power wire up through the headliner to the dome light and make your connection there.
Old 03-23-2011, 09:19 AM   #5
iicaie
Drives: Vios E
Thanks! I just tapped power for my 12V footwell LEDs from the 4K connector, pink/blue wires. However, I used some old wires from my old computer (more or less same thickness/gauge as the pink/blue ones, quite thin). I think they're around 22-26AWG, same as the original pink/blue wires, however the pink/blue wires may be solid copper core, while the wires I'm using are stranded aluminum.
Now I'm worried they might catch fire/melt/burn. What's your opinion on this? Should I get thicker gauge wires and redo the whole thing?
Old 03-23-2011, 12:15 PM   #6
That feed is fused by the DOME fuse. As long as your wires are sized appropriately for that FUSE you will be fine.
Old 03-23-2011, 10:56 PM   #7
iicaie
Drives: Vios E
This is what i'm trying to figure out, Scott. Cos the wires i used were pretty thin, 26AWG. I dont know the gauge of the original pink/blue wires coming out of the 4K connector to the dome light,
but they look pretty much the same.
Old 03-23-2011, 11:11 PM   #8
Those wires are actually 20AWG. Your 26AWG is only rated for 2.2 Amps, so to be safe you should add a 2A inline fuse between it and your new lighting.
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
