Old 06-16-2010, 07:47 AM   #1
Yarisduder
Yarisduder's Avatar
Drives: 2007 4dr Sedan Silver Streak
In my car the speedometer is set at an angle so that it's pretty much straight on from the drivers seat, I'm sure all of yours are the same. Against the GPS it reads about 6% fast, which is almost the thickness of the needle, so put the slow edge of the needle on the increment marker and it's good.
Yarisduder is offline   Reply With Quote
Old 06-16-2010, 08:24 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
In our 2007 S model sedan and two 2009 base model sedans, the speedo is set exactly straight facing the center of the back window. No tilt whatsoever. In the 2002 Echo it was angled toward the driver.
Old 06-16-2010, 09:42 AM   #3
Yaris Hilton
Smile
You're absolutely right. The cowling around the speedometer cluster is straight, but the cluster in the back is slightly angled toward the driver. Not quite straight on, but it's tilted that way a little. I'd never noticed, thanks! There's still a little parallax, and I find mine's about right when the low side of the needle is on the speed increment marker as you said.
speedometer lights pEAchEzpwnz DIY / Maintenance / Service 8 04-20-2020 09:02 PM
09 Sedan Speedometer with Tach MT Low Miles. A1phazu1u Items for Sale by private party 17 05-13-2010 05:08 AM
speedometer from TS in terra mk1 tiger Cosmetic Modifications (Exterior/Interior) 0 09-02-2009 01:15 PM
No speedometer or tachometer lights during day cdavidhess DIY / Maintenance / Service 20 06-30-2009 10:38 AM
Speedometer Trouble jonathancash DIY / Maintenance / Service 7 05-12-2009 03:04 AM
