Old 06-18-2010, 06:45 PM   #1
swidd
Drives: Yaris HB
Originally Posted by RedRide View Post
It is stiil possible the shop left an air bubble in the line somewhere no matter how good the shop is. It can happen to the best.
Well the brakes are a little better now than before the $150. I wouldn't know how to replace brake fluid anyway, and at 3 years/68,000 miles, why not. Money well spent anyway (its payday, and I spent it on my favorite thing to spend money on: the yaris!! :)
I still think it would be better to replace the brake pads though. What else would cause the pedal to have long travel (2-2.5") before giving some real stopping power?
swidd is offline   Reply With Quote
Old 06-18-2010, 07:57 PM   #2
Lucas13
Drives: 07 Yaris LB
The other cause will be a master cylinder that is not holding enough pressure but in a car with only three years it’s almost impossible, air in the system is the main cause for a mushy brake feel. Some mechanics use one men bleeding tool and if the guy is not careful enough air can go in very easy just in one second, just one little bubble can become hundred little bubbles and make the brakes ineffective.
The other thing you should try is pulling normal the e-brake and count how many clicks it’s doing until stops, normally is two clicks when just adjusted, if it does more than three it needs more adjustment, the other way to check the rear brake is by removing the wheel and making sure that the drum doesn’t spin like crazy when you turn it, it should do about ½ turn when just adjusted.
Lucas13 is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
brake question stuffy DIY / Maintenance / Service 12 06-18-2010 05:04 PM
Brake question xen555 DIY / Maintenance / Service 8 03-06-2009 05:14 PM
Help Needed - Brake Light Question *MAD DOG* Cosmetic Modifications (Exterior/Interior) 21 02-08-2009 05:32 AM
