Old 03-05-2009, 11:16 PM   #1
xen555
xen555's Avatar
Drives: 3 DOORS LB
Brake question
It is posible to replace the rear drum with the OEM front disk brakes???
xen555 is offline   Reply With Quote
Old 03-05-2009, 11:19 PM   #2
silver_echo
ekodrvr
silver_echo's Avatar
unsure but i do know that there is a kit for the conversion...
http://www.yarisworld.com/forums/showthread.php?t=14452
silver_echo is offline   Reply With Quote
Old 03-05-2009, 11:28 PM   #3
xen555
xen555's Avatar
Drives: 3 DOORS LB
thanks i know that kit and its 900 U$S
i found a junker selling the front brakes for 100 u$s
Old 03-05-2009, 11:33 PM   #4
silver_echo
ekodrvr
well for a direct answer to a direct question, ANYTHING is possible... the difference between not done and done will be a combination of skill and money... if less skill, it will be more money...
Old 03-05-2009, 11:37 PM   #5
supmet
Drives: 2007 4 Door Yaris
everything in the front brakes? Even if you get the whole caliper set up, you'll have to find a way to mount it. Unless you're REALLY good with fabrication I wouldn't try.
Old 03-06-2009, 12:07 AM   #6
silver_echo
ekodrvr
also, you need to think about the parking brake...
Old 03-06-2009, 01:34 AM   #7
Brian
Brian's Avatar
I recommend the rear disc brake conversion because its designed for our cars and easy to install.
It's expensive but well worth it.
Old 03-06-2009, 02:15 PM   #8
xen555
xen555's Avatar
Drives: 3 DOORS LB
thanks for the replys guys!!!
i forgot about the e-brake mmmmmm...
if a try this mod i post the DIY
Old 03-06-2009, 05:14 PM   #9
Brian
Brian's Avatar
Here is the DIY that I used. Its just missing the e-brake part but that's easy to figure out.
http://www.yarisworld.com/forums/sho...light=lug+nuts
Help Needed - Brake Light Question *MAD DOG* Cosmetic Modifications (Exterior/Interior) 21 02-08-2009 05:32 AM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
