Old 06-19-2010, 07:56 PM   #1
Billiam
Drives: '10 White Yaris 4D LB
Originally Posted by Revsson View Post
...However, I am real leery of taking off the steering wheel for the light stalk....
There are other options. For example, I removed all of the switch leads from my wire-harness and have the fogs relay'd off of the parking lamps. They function with the parks, low and high beams....no stalk switch...or any wiring in the cabin for that matter.
BTW, nice jobs on the fogs fellas. Looks like you guys went with the factory bezels? Too clean to be that aftermarket one...yes?
Old 06-21-2010, 10:07 PM   #2
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Thanks Billiam. Originally I wanted to go factory but I actually didn't get to try the factory fog light stalk since the kit I bought off eBay came with everything I needed (yes, even the bezels). Not the best fit but they will do for now until I get the "good stuff" from the dealer.
I just got the instrumental panel fog lights indicator to work as per CTScott's directions -- He's da man!
Washed and vacuumed!
-toy
Old 06-22-2010, 04:39 PM   #3
Billiam
Originally Posted by toy_toronto View Post
I just got the instrumental panel fog lights indicator to work as per.....He's da man!
Yes...he knows a great deal. I even told him so the other day.
I may do the idicator trick as well.
Looks like the fit for the bezels as improved over the older '09+ kit that I saw.
Old 06-22-2010, 06:05 PM   #4
toy_toronto
always toyin'
Drives: 2010 5-Dr
Yes the bezels aren't too bad there is a slight gap at the top (less than 1mm) where you can see some light shine through but it isn't noticeable at all.
The fog lights seem to be of good quality (glass, not plastic). The entire kit cost $115 with shipping included.
As for the fog light dash indicator, I would say if you can tap 12V from the the fog lights switch (when flipped to "ON") wires and feed that 12V signal to the D2 connector Pin 7 red wire, it would take you no more than 15 minutes to fire up that indicator
(* that includes removal of the front instrument panels to get to the cluster/D2 conn).
-toy
Old 06-22-2010, 06:01 PM   #5
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
toy_toronto, I envy the fact that the Canadian indicator for your headlights looks like, well, headlights... way better than the USDM lightbulb thing. You know despite the fact that the icon switch looks like what's on your Canadian dash. Why can't they make it look the same?
Car looks great! Dig the wheels, what are they?
I've got to do a photoshoot here sometime soon as well, 'cause I'm jealous of your
Old 06-22-2010, 06:12 PM   #6
toy_toronto
always toyin'
Drives: 2010 5-Dr
LOL thanks :) I can't wait to see your photoshoot
The wheels are 17's Enkei CDR9. I do like them and I'm glad I picked them and no regrets... They weigh around the same as the OEM steelies.
cheers. -toy
diy, foglights, problems
mechanic in our area why? Southeast 3 02-08-2010 02:03 PM
60K Service by Dealer or Independent Mechanic? tomato General Yaris / Vitz Discussion 33 01-19-2010 06:42 PM
Shade tree mechanic tip #523: Carboard boxes make great creepers! schleppy DIY / Maintenance / Service 2 04-22-2009 01:30 PM
P0420 UPDATE - listen to my mechanic telling my grandma what needs to be done next... la_scanner DIY / Maintenance / Service 0 04-03-2009 09:18 PM
Pa/Ohio Mechanic Type Pitt Yaris NY / NJ/ CT / PA 7 04-02-2009 08:12 AM
