Old 06-22-2010, 01:59 PM   #19
kou
Drives: 08 lb
No CEL after 2 days and half a tank of gas.
Only have high idle on cold start for 20-30 seconds then its all normal operation.
Old 06-23-2010, 06:13 PM   #20
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Good to see a port-matching job! If I could do this on the cheap, I'd probably give it a go.
Old 06-23-2010, 08:13 PM   #21
Astroman
Modded Moderator
Astroman's Avatar
You would'nt happen to have any pics of the porting do you? I did the TB swap but just bolted on the new one w/o doing much else. (No CEL either.)
Old 06-23-2010, 08:34 PM   #22
mario98c
mario98c's Avatar
Astroman do you use the corolla tb with the yaris tb chipor you use the corolla one?
Old 06-23-2010, 09:04 PM   #23
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Both ways work. I have a 1ZZ TB with a 1NZ chip, no CEL. Just a high idle for the first 30 seconds or so.
Old 06-23-2010, 10:47 PM   #24
mario98c
mario98c's Avatar
So all i have to do is put jbweld in all the openings of the intake manifold then make the chip swap then make the idle screw adjustment and install everything up? i am correct?
Old 06-24-2010, 12:24 AM   #25
Astroman
Modded Moderator
Astroman's Avatar
I used the corolla TB and chip. Bought mine from FunctionSpec. It had a different part number though than what everyone else seems to be able to find. Mine was off of a 05 Corolla, no chip swap or idle screw adjustment.
Old 06-24-2010, 12:27 AM   #26
mario98c
mario98c's Avatar
Can you give me the part number if not too much trouble?
Old 06-24-2010, 12:36 AM   #27
Astroman
Modded Moderator
Astroman's Avatar
Not at all: #22030-0D030
I found this by searching ebay right now. Although I paid about half that on here, but it's the only one with that part # I've found on here.
Old 06-24-2010, 12:40 AM   #28
mario98c
mario98c's Avatar
Thanks Bro
Old 06-24-2010, 12:41 AM   #29
Astroman
Modded Moderator
Astroman's Avatar
Your welcome! Hope you get one, and if you do please post your findings and results.
Old 06-24-2010, 12:45 AM   #30
mario98c
mario98c's Avatar
ok. Not problem
Old 06-24-2010, 06:39 AM   #31
sito
Drives: Toyota
Astroman, did you experience abnormalities when the aircon kicks in?
While my car was stopping (with aircon on), i could feel jerking and my car moving forward even i stepped on my brakes..
And did you experience oscillations while driving?
I have the same throttlebody number as yours and have not done any chip swap or idling screw..
Going to try the chip swap soon....
sito is offline   Reply With Quote
Old 06-24-2010, 11:54 AM   #32
Astroman
Modded Moderator
Astroman's Avatar
No I haven't noticed any abnormalities except at cold idle startup, but I've only used the A/C once or twice. Once it gets HOT here (which will be next month thru august) I'll check it out more.
Old 06-25-2010, 04:39 PM   #33
sito
Drives: Toyota
Thanks Astroman....
Old 06-27-2010, 02:34 AM   #34
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Originally Posted by kou View Post
I ordered a new intake manifold, a yaris and a corrola throttle body.
Nice work mate enjoy your workmanship
Is this the 1ZZFE throttle body?
Parmas is offline   Reply With Quote
Old 06-29-2010, 03:02 PM   #35
kou
Drives: 08 lb
Thank you, and yes it is the 1zzfe throttle body.
Old 07-02-2010, 02:11 PM   #36
kou
Drives: 08 lb
So its has been a week and still going great.One cel/code popped up which was a p0171(bank 1 system lean.)This only happened once on a 95degree day with high humidity the AC on stuck in traffic,cel turned off on it's own the next day so i am sure its because of the conditions that day caused the cel.High humidity not good.
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
1ZZ-FE throttle body crxgames Items for Sale by private party 1 04-27-2009 05:19 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
DIY: Tricking ECU Throttle Body Relearning gwasabi DIY / Maintenance / Service 2 04-03-2009 07:02 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
