Old 06-24-2010, 02:02 PM   #3
big lo
big lo's Avatar
Drives: 2007 VIOS
If you have the OEM ones where you have the fog light switch as part of the headlight stalk then do the following to allow them to come one with either the high or low beams:
Take the wire that is in pin 4 of the headlight stalk (it will be orange, beige or white, depending on year and if you have DRLs) and cut it (leave yourself some room on either side of the cut to be able to work with the wire.
Take the harness side of the cut wire and cap it off.
Take the connector side of the wire and tap it to the white wire in pin 13.
Attachment 34678
Thanks for the info, just to let you know my is the 2007 sedan S class. Now as for the harness thats located to the fuse box correct? The colors that are here is red, green, light green and two that are spaced with green and grey, so run that by me again please.
Sorry! Another fog light question. Jrilla DIY / Maintenance / Service 4 08-23-2009 02:25 PM
Question about Yaris 2009 fog light? JAyala Cosmetic Modifications (Exterior/Interior) 0 02-07-2009 03:51 PM
fog light lens question? Adriaan Cosmetic Modifications (Exterior/Interior) 0 04-13-2007 11:30 AM
question on Fog light clfile Cosmetic Modifications (Exterior/Interior) 6 11-09-2006 07:11 PM
