Old 06-26-2010, 03:11 PM   #1
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
Originally Posted by Focus_Sh1ft View Post
Dibs on being the guinea pig (if one is even necessary) if it nets me a discount.
The kit has been running on the guys car for like a year now and makes 150-160whp. My concern besides a base map is the line from the oil pan, will you include a tapped pan, or will we have to tap ourselves. I just ask because I have to travel 1-2hrs away to go to a shop if i can find anyone locally to do it. I'm 99% sure I can, but it may be the same or worse for other people wanting to buy the kit. I guess you guys will work out the datails but If I was going to buy the kit I would want: manifold, turbo, downpipe (with bung for air/fuel) , intercooler, piping, oil pan with tap, lines and fittings, manual boost controller, BOV (with option for hks or greddy), EMS with basemap, and all hardware & instruction needed.
also are you going to do both water and oil cooled lines? and pnp harness option?
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 06-26-2010, 04:05 PM   #2
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Dyno sheet please.
Old 06-26-2010, 07:20 PM   #3
cdydjded
Drives: Yaris LB Turbo
Originally I was going to include the Zage pan. I bought one put it on my car & it does not work. The only other option is for the installer to drill a hole on the upper portion of the factory pan.
As for the turbo, option 1, which will be a T28, has for both water & oil but only the oil is absolutely necessary. The water is optional. Option 2, which will be a GT2554R will need both I believe.
Bolt on turbo kit for our yaris! aucorium Forced Induction Forum 57 02-02-2010 07:50 PM
Turbo on an Automatic Yaris S Sedan...? Dadombomb15 Performance Modifications 4 11-07-2009 02:04 AM
Turbo, Supercharged, NA Yaris 1/4 mile times??? hatchbackkid82 Forced Induction Forum 15 07-12-2007 03:58 AM
