C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
OK yesterday I ordered Garms Turbo manafold off Micro Image and also a GT25 turbo from E-bay. I will see how it mounts up then I will start planing costom intercooler piping and downpipe routing. Also will need to measure for oil feed and return line. And what I will need to tap pan for retun line. Any sugestions for return line tap would be helpful.
![]() Turbo specs. I think this turbo should spool quickly and be good for low boost application TURBO SPEC: gt25 internal wastegate turbo charger Intake :2.5 inch Outlet: 2 inch Compressor trim: .42 ar Compressor Wheel diameter: 60.05 /42.12 Turbine wheel diameter : 46.46 /53.20 Exhaust trim: .49ar Turbine flange type: t25 flange Downpipe flange type : 5 bolt type (will not fit sr20 down pipe bolt pattern) Cooling type: oil and water cool Actuator : set at 8psi Horsepower rating: 250-300hp+ (wet float bearing) 1 YEAR WARRANTY IF INSTALLED BY PROFESSIONAL MECHANIC ( ASE CERTIFIED) Turbo was $239.99 shipped to my door |
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 02:02 PM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| ZPI soon to release their turbo kit | turboyaris | Forced Induction Forum | 10 | 04-26-2007 02:52 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
