![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
Ok so I rewired my foglight setup as it seemed stupid to pursue the original setup when I knew I could do something else. I bought a simple rocker switch at radioshack. I have the acc wired in for supply and the output directly to the fogs (with the switch grounded and acc wire fused of course). I also tapped the fog light in wire into pin 7 on the D76 connector on the combination meter to fire the fog light indicator. Everything works perfectly.
![]() I'm wondering though... how safe is this without a relay? From my understanding a relay is used as a means for a low voltage switch to control a high voltage current. In the aftermarket harness, I believe both the switch and fogs receive 12v, so what's the point of a relay? |
#2 | |
So they do use different current afterall? It's still kind of interesting how relays are used here, whereas the proper switch eliminates the need for it...
CTScott, any hunches on the initial problem? It remains unsolved. Although unimportant now, I hate not being able to figure things out
#4 | |
As for the initial problem, I would suspect a bad ground connection. All of the lighting circuits on the Yaris are switched on the ground leg, so to complete the circuit you have to ground it. |
| my Projector Fog lights project | ezhacker1 | Cosmetic Modifications (Exterior/Interior) | 3 | 01-10-2010 05:21 PM |
| Fitting Front Fog Lights OEM - Yaris 2007 3dr | weller | Cosmetic Modifications (Exterior/Interior) | 1 | 12-17-2009 12:29 PM |
| Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) | Lafiro | Cosmetic Modifications (Exterior/Interior) | 2 | 06-12-2009 03:56 PM |
| Need Help Wiring Fog Lights | MadMax | Cosmetic Modifications (Exterior/Interior) | 29 | 11-29-2008 06:31 PM |
| Disabled DRLs and Factory fog lights | DARKYARIS | DIY / Maintenance / Service | 21 | 05-01-2007 05:32 PM |
