Ok, thanks for the great picture. So I may or may not have the correct connector for the clockspring. Guess I won't know until I open the steering wheel. Keeping my fingers crossed!
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed. |
Look at the connector on your Corolla harness. If it is a 4 pin connector, like the white one in my photo, then you are OK. If it is larger than that, then you will have to move the pins over.
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
CScott and all 2008 CND Sedan owners.. I have read most of the threads on the CC and since most are about the US version of Yaris, I just want to confirm for the CND version.
I am wanting to install the OEM steering wheel CC control stalk, I do not need any additional running of wiring from the small 4 pin connector in the steering wheel other then from the CC stalk to the connector.. Sorry guys if this is a repeat question.. regards |
#4 | |
Hi Scott and all.. For the lift of me, I can not identify the D3 connector as in the DIY document to confirm if I have CC pre wired for the sedan.. Should it be visiable from under the dash area with out having to remove any covers?
thanks all! |
It's on the steering column, and requires removing the lower column cover to see it. Just remove the screw by the steering wheel tilt lever and the two that become visible when you turn the steering wheel.
Good news for CND 2008 Sedan owners.. The wiring is there to the ECN.
Not sure about the US version of 2008 Sedan and if the wiring to the ECN is there.. Here is a photo I took of the ECN connector.. |
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
