Old 07-31-2010, 05:13 PM   #11
CB900F2
Drives: 08 Sedan
Hi Scott and all.. For the lift of me, I can not identify the D3 connector as in the DIY document to confirm if I have CC pre wired for the sedan.. Should it be visiable from under the dash area with out having to remove any covers?
thanks all!
On your 08 sedan, I am pretty sure that you will need to run the wire from the other end of the clockspring to the ECM, as all 08 liftbacks require that wire to be run.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
