Old 09-08-2010, 12:38 PM   #11
sheraz2000
sheraz2000's Avatar
Drives: Vitz 2006
Send a message via MSN to sheraz2000
If the Belta has blue and brown as the other two wires in D3, then it should work. If it has the cruise control indicator in the cluster, then to test it just jump the blue to the brown with the ignition on and the CC indicator should light.
For the other, which just has the black wire, the best quick test is to measure the voltage on the ECM pin (A21-Pin 40) with the ignition on. If CC is active on the ECM, then that pin will have 12V on it.
well, when i opened up the D3 connector on my belta, i got these wires. Tell me what to do from here forward. SORRY about the blurry pic, was taken from my mobile cam. But the wire colors r pink, orange, grey and black. there is no blue and brown cable. How to check if my car has CC in ECM.
---- its fun to be in a vitz!
sheraz2000 is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
