Old 07-19-2010, 09:15 PM   #1
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
That's great infomation here!! The resistor is to add in the parking light, may i ask, is the resistor add in before the diode or after the diode?
Won't the wire of the parking & brake signal light be "shock" circuit when i step on the brake padal?
In other word, i can just simple use the standard bulb instead of "twin" wire bulb?
Won't the standard bulb "blow" off if apply brake with the parking light on? (over-voltage)
Sorry CTScott for the many questions. It been many years since i last read my electronic/electrical books.
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 07-19-2010, 10:54 PM   #2
The resistor goes before the diode.
The diodes keep the two circuits from feeding each other, as they only let current flow in one direction.
JDM leather wheel OR JDM Vitz RS rear bumper??? evo165 Cosmetic Modifications (Exterior/Interior) 31 02-14-2012 08:26 PM
JDM Vitz RS rear bumper where to find????? DeathBeard General Yaris / Vitz Discussion 3 06-28-2010 11:11 PM
HKS hi-power fitted to Jdm rs rear bumper blacksandiegovitz Performance Modifications 4 06-20-2010 11:17 PM
jdm rs bumper kiwi Cosmetic Modifications (Exterior/Interior) 5 11-01-2009 02:17 PM
FS: JDM Modellist II Front bumper & JDM LED tails DKN-YARIS Items for Sale by private party 7 11-09-2008 01:10 AM
