Old 07-23-2010, 08:14 PM   #1
shinlee
shinlee's Avatar
Drives: 07 liftback
well, if you want the drivability (i.e. less noise when you're cruising at highway speeds) the stock res is fine. Hell, irregardless, the stock res is fine if you're running a 2'' pipe. I personally looked at it myself before my exhaust was put in, and it is a straight flow through 2'' center resonator. (That's why I chose 2'', no point going bigger than the smallest point on the system, ya know?) So a glasspack or stock res should net exactly the same power, just differnt noises :)
shinlee is offline   Reply With Quote
Old 07-23-2010, 10:23 PM   #2
SLIK4
Michael
SLIK4's Avatar
Drives: 07 Silver Yaris Sedan
what kind of noise difference would the glasspack make? louder or quieter? deeper maybe?
SLIK4 is offline   Reply With Quote
Custom 1.75" catback exhaust - worth it?? fuji Performance Modifications 4 05-09-2009 06:46 AM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
Custom exhaust or pre-made exhaust - which one makes more power? fuji Performance Modifications 9 03-08-2009 12:24 AM
Custom Cat-Back exhaust Yaris TS CASTREX Yaris TS Talk 16 10-24-2008 12:56 PM
How much has your custom exhaust cost you? whooppee777 Performance Modifications 7 07-21-2007 11:20 AM
