Old 05-08-2009, 05:24 PM   #1
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Custom 1.75" catback exhaust - worth it??
I had a 2" custom exhaust installed not to long ago. I was hoping to see a bit more oomph in the mid to upper ranges but the results have been slightly diappointing. I definately noticed the lack of oomph in the lower end.
I know most people would install a 2" or 2.25" piped exhaust but is there a way to constuct a free-er flowing 1.75" that would restore the lower end oomph while giving some benefit up high as well?
Any difference in power when adding resonators and high flow catalytic converters? Just better not to run a resonator???
fuji is offline   Reply With Quote
Old 05-08-2009, 05:50 PM   #2
gwasabi
Drives: 07 Blazing Blue LB
leave it at 2 and get corolla tb
Is it a CAt delete?
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-08-2009, 05:57 PM   #3
gwasabi
Also, if you have a pulley set, you might want to change back your CRANK PULLEY to OEM. I noticed that the torque kinda sucks on the lower end with it on
Serious Business...
Old 05-08-2009, 09:13 PM   #4
fuji
fuji's Avatar
The cat is currently in place. Is there any advantage to having a hi flow cat installed???
Old 05-09-2009, 06:46 AM   #5
gwasabi
Keep the cat if you want the backpressure.
Serious Business...
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
Custom exhaust or pre-made exhaust - which one makes more power? fuji Performance Modifications 9 03-08-2009 12:24 AM
Custom Cat-Back exhaust Yaris TS CASTREX Yaris TS Talk 16 10-24-2008 12:56 PM
Custom Catback System Sabretooth Performance Modifications 48 07-10-2007 09:59 AM
Catback exhaust? elsteverino889 Performance Modifications 5 03-09-2007 10:55 AM
