Old 07-25-2010, 10:31 PM   #1
Originally Posted by CB900F2 View Post
CScott and all 2008 CND Sedan owners.. I have read most of the threads on the CC and since most are about the US version of Yaris, I just want to confirm for the CND version.
I am wanting to install the OEM steering wheel CC control stalk, I do not need any additional running of wiring from the small 4 pin connector in the steering wheel other then from the CC stalk to the connector..
Sorry guys if this is a repeat question..
regards
On your 08 sedan, I am pretty sure that you will need to run the wire from the other end of the clockspring to the ECM, as all 08 liftbacks require that wire to be run.
Old 07-31-2010, 05:13 PM   #2
CB900F2
Drives: 08 Sedan
Hi Scott and all.. For the lift of me, I can not identify the D3 connector as in the DIY document to confirm if I have CC pre wired for the sedan.. Should it be visiable from under the dash area with out having to remove any covers?
thanks all!
CB900F2 is offline   Reply With Quote
Old 07-31-2010, 10:00 PM   #3
thanks all!
It's on the steering column, and requires removing the lower column cover to see it. Just remove the screw by the steering wheel tilt lever and the two that become visible when you turn the steering wheel.
Old 08-01-2010, 08:10 PM   #4
CB900F2
Drives: 08 Sedan
Good news for CND 2008 Sedan owners.. The wiring is there to the ECN. I will assume all the wiring in the steering wheel is also present..
Not sure about the US version of 2008 Sedan and if the wiring to the ECN is there..
Here is a photo I took of the ECN connector..
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
