Old 07-31-2010, 11:47 AM   #1
RedRide
RedRide's Avatar
Originally Posted by Billiam View Post
Ok....here's what's going to happen. You're going to get a different answer with each post. Everyone has their favorite oil and filter. There is no "best" oil. There will be an argument or 2 about which oil "better"...usually from the synthetic users...my oil can beat up your oil type stuff. Then after a few days the thread will probably be locked. No worries though, as a new one will pop up right behind it.
So...go to your favorite store and find some 5w-20 and a filter and be happy. Any and all modern oils (dino and synth) will protect your engine just fine for 5000 miles (however many KMs that is). The most important thing is to follow the recommened intervals and proper oil weight.
Oh...and for the record...I've used Castrol GTX and a PureOne filter on all of my cars for as long as I can remember.
Now excuse me...as I go pop some popcorn and sit back and watch another oil thread "evolve".
Exactly!
Any compitent mechanic will tell you that most all modern oils are basically the same and the important thing is to just change it frequently.
BTW, as I understand it "high milage" oil is just oil with some added detergents to help clear out sludge. However if you change it often you will not have sludge to begin with.
Old 07-31-2010, 04:39 PM   #2
mimelio
Drives: NONE
Originally Posted by RedRide View Post
Exactly!
Any competent mechanic will tell you that most all modern oils are basically the same and the important thing is to just change it frequently.
BTW, as I understand it "high mileage" oil is just oil with some added detergents to help clear out sludge. However if you change it often you will not have sludge to begin with.
+1
mimelio is offline   Reply With Quote
Old 07-31-2010, 07:57 PM   #3
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Originally Posted by mimelio View Post
+1
++1.....use what your manual says,can't go wrong!.
frog13 is offline   Reply With Quote
Synthetic VS. Regular oil reliability captainm27 DIY / Maintenance / Service 98 01-20-2010 01:46 PM
Anyone running Royal Purple? firebird1999us DIY / Maintenance / Service 80 02-27-2009 10:30 PM
