Old 08-08-2010, 10:47 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
I am recently installing a new engine management and I got a doubt about the coils connection terminals.
In the engine managment manual it says that the positive terminal must be common with all coils while the negative terminals must be connected with external ignitors then to ecu. The problem is that the common wire in the coils stock loom is color coded Black and White and I am suspecting that the wiring needs to be adjusted to match the my management.
Scioncrew.. since you have experience with these coils, do you know which of the terminals is negative or positive?
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
Custom Turbokit 1nz Forced Induction Forum 58 10-09-2009 03:01 PM
Moving the Ignition To The Left? MadMax Cosmetic Modifications (Exterior/Interior) 4 10-02-2009 11:57 PM
Ignition locks? Blowtorch DIY / Maintenance / Service 4 05-13-2009 12:26 PM
