Old 08-08-2010, 01:00 PM   #1
cdydjded
Drives: Yaris LB Turbo
Originally Posted by pimp my yaris View Post
Update: I ordered a front mount intercooler and 2.25" piping kit and also an additional piping kit as well and a adjustable bov that can be piped to recirculate. And a oil feed line with t fitting to tap into pressure sensor. This size should work well. My turbo,T/B and air box should fit 2.25" silicone connectors. I am going to try to use the stock air box and mass air. It may cause problems with fitting intercooler piping later though. I also have a question guys> Where are you tapping into to get your coolant for the water lines on the turbo?? I am thinking heater core lines would be the most obvious choice. But Im not positive.
If anyone is intrested, so far I spent 876.99$ including shipping
2.25" is correct on the I/C pipe size. You will not be able to use the stock air box, it wont be able to be pressurized. IMO you do not have to flow coolant through the turbo.
cdydjded is offline   Reply With Quote
Old 08-09-2010, 04:31 PM   #2
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
I am planing on putting the mass air before the turbo. That way I can hopefully use stock air box and cut down on costs.
pimp my yaris is offline   Reply With Quote
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
