Old 08-19-2010, 04:38 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
No need for the PMs...
It's a purple wire, but I don't have my EWD on hand to tell you what connector... I'll see If I can find it.
Edit: ok found it. I have a '04 manual, so as long as you have a 4 connector ECU it should be the same. It's a purple wire with white tracer, pin 17, connector B.
Old 08-19-2010, 05:22 PM   #2
ali077
TRD TURBO
Drives: TRD VITZ TURBO 2003
but the arrangement of the wires on my ECU is completely different as mine is a turbo. its the same 1nz-fe engine but with factory fitted turbo. the code of my ecu is 1nz-fet. its does have 4 connector and does have a purple wire with white tracer but not in connector b and pin 17 as stated. shall ill try to connect it to the wire though?
btw thx for ure help. much appreciated.
ali077 is offline   Reply With Quote
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
Engine intake air flow not smooth on certain speed and gear? ammophobia DIY / Maintenance / Service 3 07-17-2009 03:31 AM
