Old 08-23-2010, 08:00 PM   #1
coheed
Drives: 08 BB LB
Originally Posted by cdydjded View Post
My kit will be complete. Turbo, manifold, downpipe, all nuts, bolts, gaskets needed, I/C with piping, hose & t bolt clamps, injectors, everything! No cutting will be necessary, only drilling & a small amount of grinding. The only parts I do not include in my kit are:
Exhaust
Gauges
AEM FIC or eManage
But I can add those above items or any others as an option.....
Well I'm wanting to do 10psi daily and bump it up for track days. Things I'm concerned about are:
1. Will I need to sleeve the block if going to 15psi on the track maybe once every 2 months (if that)?
2. Will the injectors you supply be enough for 10psi everyday?
3. Will I have to upgrade coils at that boost level?
According to zage's website they got 190bhp at .5 bar (7ish psi), so I was wanting to shoot for a lil over 200 at 10psi daily. And you've probably posted this but I'm to lazy to search for it right now, what turbo and trim would this be using? I was thinking t28 or gt28 with 54-64 trim level, in that range.
The only reason I posted this in this thread is someone may want this info in the future and maybe other people have input on my questions.
Old 08-23-2010, 11:02 PM   #2
cdydjded
Drives: Yaris LB Turbo
Originally Posted by coheed View Post
Well I'm wanting to do 10psi daily and bump it up for track days. On a stock motor with stock rods & pistons i would not suggest to run more than 8lbs maxThings I'm concerned about are:
1. Will I need to sleeve the block if going to 15psi on the track maybe once every 2 months (if that)? The factory sleeves are not the problem, the issue is the factory pistons & rods
2. Will the injectors you supply be enough for 10psi everyday? Apply above answers
3. Will I have to upgrade coils at that boost level? No
If you want 200hp you will have to upgrade the pistons & rods on the 1NZ. My kit or any for that matter, on an 1NZ with upgraded pistons/rods & other supporting mods (fuel system & good tune) will make 225-250hp @ 10-15lbs.
cdydjded is offline   Reply With Quote
Old 08-24-2010, 01:17 AM   #3
coheed
Drives: 08 BB LB
I was deffinitely planning on replacing rods and pistons. I wouldnt turbo any motor at 10psi or above without replacing those.
Bolt on turbo kit for our yaris! aucorium Forced Induction Forum 57 02-02-2010 07:50 PM
Turbo on an Automatic Yaris S Sedan...? Dadombomb15 Performance Modifications 4 11-07-2009 02:04 AM
Turbo, Supercharged, NA Yaris 1/4 mile times??? hatchbackkid82 Forced Induction Forum 15 07-12-2007 03:58 AM
