#91 |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
Sounds like you guys are going to have this ready in perfect timing for be to buy it =)
Also, I have to vote that selling something with a tune map preinstalled would be a HUGE help. Tuning costs can be huge and are something some people might not consider before actually buying the kit. A tune designed to run in California would be just awesome... we do have one of the highest populations / per state so it could be used by lots of people! |
#92 |
Mr. 155 and climbing
Any status update on this? Not to be cliche, but after doing a few months research it is becoming more and more of a daunting task to swap a 2zz into my sedan. I mean a decent rebuilt 2zz will run 5-7k alone just for the long block. No tranny, no EMS, no LSD, no upgraded suspension, no exhaust system. My real goal would be the 150-160hp range which sounds like it could be a solid and stable setup that is in the works.
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. Last edited by fnkngrv; 08-23-2010 at 02:23 AM. |
#93 | |
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
Too much of car culture is people taking things too seriously and not enjoying it for what it is. |
#94 |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
My kit will be complete. Turbo, manifold, downpipe, all nuts, bolts, gaskets needed, I/C with piping, hose & t bolt clamps, injectors, everything! No cutting will be necessary, only drilling & a small amount of grinding. The only parts I do not include in my kit are:
Exhaust Gauges AEM FIC or eManage But I can add those above items or any others as an option..... |
#95 | |
1. Will I need to sleeve the block if going to 15psi on the track maybe once every 2 months (if that)? 2. Will the injectors you supply be enough for 10psi everyday? 3. Will I have to upgrade coils at that boost level? According to zage's website they got 190bhp at .5 bar (7ish psi), so I was wanting to shoot for a lil over 200 at 10psi daily. And you've probably posted this but I'm to lazy to search for it right now, what turbo and trim would this be using? I was thinking t28 or gt28 with 54-64 trim level, in that range. The only reason I posted this in this thread is someone may want this info in the future and maybe other people have input on my questions.
#96 |
1. no
2. 10 yes, 15 probably not. 3. no The Yaris stock fuel system runs out at about 13 psi. Above that, you'll need a stronger pump, and at some point a return line. Best turbo for 150-200 is a GT25 so you get a nimble spool-up. A GT28 is going to feel laggy.
#97 | |
#98 | |
#99 |
I was deffinitely planning on replacing rods and pistons. I wouldnt turbo any motor at 10psi or above without replacing those.
#100 |
Again sorry to thread jack.
Would I be able to achieve my goals with a turbo thats 0.60 A/R Compressor, 0.49 A/R Exhuast side? For some reason I feel like the exhaust side a/r would limit me.
| Bolt on turbo kit for our yaris! | aucorium | Forced Induction Forum | 57 | 02-02-2010 07:50 PM |
| Turbo on an Automatic Yaris S Sedan...? | Dadombomb15 | Performance Modifications | 4 | 11-07-2009 02:04 AM |
| Turbo, Supercharged, NA Yaris 1/4 mile times??? | hatchbackkid82 | Forced Induction Forum | 15 | 07-12-2007 03:58 AM |
