#127 | |
#128 |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
Cant wait to hear how it drives.
#129 |
I can't wait to SEE how it drives.
I'm ready to start the car / crank the engine, but I'm currently doing battle with Zage's pan. This thing sucks. It's barely leaking at the moment from the side of the pan where the two nuts go on, but they don't fit on the Zage pan. Even after doing some drilling to try to get them to thread the stems I've had no luck. Waiting for my silicon + JB Weld to dry and see if I finally have a seal, after having to take it off again earlier. |
#130 | |
Only Happy When it Rains
Colin Chapman disciple |
#131 | |
#132 | ||
IF I ever get to that part... Just poured in some oil and guess what LEAKS Here's a quick time line of emotions: ![]() ![]() ![]() ![]() ![]() ![]() ![]() then of course: ![]() I sealed the whole inside edge of the pan this time, so I honestly don't know what to do. I drained the oil again and put some more sealant on the outside edge of the pan. This is exactly how things went last time. I fought a losing battle against leaks... I guess this time I'll be sure I give the silicon plenty of time to atleast tack? ![]() Anyways, I've run out of things to do. Here's all that was left to do today (I can't reach the turbo / manifold with heat wrap while the car is raised). ![]() ![]() So... yeah. I was originally going to do the oil feed and return first. I'm glad I didn't, because this whole situation is VERY discouraging. |
#133 |
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
This maybe a stupid question, but was the surface being sealed clean before you put the pan on? Seen a few people try to put new oil pans on with out taking old gasket material off the surface before. Not saying your dumb just posing the question.
Too much of car culture is people taking things too seriously and not enjoying it for what it is. |
#134 | |
It's so frustrating to be stuck because of a minor leak that I simply can't plug... |
#135 |
Bathroom + Laptop = <3
What kind of sealant are you using.
Take some pics of the area that is bad and how bad the holes are not lined up, maybe we can think of something to help you out. I've only used JB Weld once on my car is when the mounting hole on my charge pipe came off -_- |
#136 |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
giant zip ties on the intercooler is DEFINITELY ftw
#137 |
#138 |
I don't know your process for mounting the oil pan but here's how they should normaly go on...
1. clean everything with a clean rag and make sure there is no oil were the silicone will seat. 2. lay a bead around the pan about 1/8" thick making sure you go all the way around the bolt holes. 3. when assembling, only snug the bolts enough to start pressing the silicone out the side. 4. let dry. 5. tighten the bolts to spec. (probably around 15-20 ft/lbs. not very tight) Even if the pan is warped it should still seal with the method. |
#139 |
Leak is dealt with.
I'm currently having issues priming the turbo though. Pulling the EFI fuse and spark plus didn't cut it. I'm also worried to continued because at this point I most likely am flooding the engine with fuel, even after pulling the injector plugs. |
#140 |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Start the freakin car! I did not & have never primed a turbo. Once you start the car oil will go to the turbo immediately....
#141 |
Car started AND............
![]() ![]() ![]() ![]() You guys gotta hear this thing! I'll take a video later. I currently have a small leak coming from the banjo bolt, and atleast one of my coolant lines is leaking. My only concern was that the manifold / turbo / downpipe began smoking, but I think that may be the iron oxide burning. Definitely would like to hear some feedback regarding that. |
#142 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
If you used Silicone Heat resistant coat and wrapping on exhaust these are surely the ones making that smoke. This smoke will last till 15minutes and would normally happen only at the first heatup after installation so be cool |
#143 | |
![]() Just to clarify, a turbo timer shouldn't be necessary since I have the turbo water cooled, correct? |
#144 | |
| FS: Autometer Cobalt 6170 Boost Gauge | Nexus1155 | Items for Sale by private party | 2 | 02-02-2011 04:08 PM |
| Multiple cylinder misfire under boost | LtNoogie | Forced Induction Forum | 13 | 11-02-2009 04:44 AM |
| Fill up with Super before starting your boost project | LtNoogie | Forced Induction Forum | 5 | 12-01-2008 06:41 PM |
| Supercharger Selection and Limiting Boost | Nexus1155 | Forced Induction Forum | 1 | 12-01-2008 03:51 PM |
| WTB: Boost Gauges | Teruyume | Items for Sale by private party | 4 | 11-12-2006 02:42 PM |
