Old 08-25-2010, 10:23 PM   #11
Originally Posted by Nebarnix View Post
Not really interesting in hotwiring so much as DIY remote start. Except I don't plan on buying a module, I'm going to build it from scratch and use my EZ430 Chronos RF wrist watch to send packets to the radio which will start the car and lock / unlock the doors and activate an APRS beacon (all sorts of fun!).
In your guide you do not talk about which wires actually carry what information (voltages etc). Can you list more specifics? Is there a single 12V line that gets jumpered to the various other wires which then trigger relays? If so, then this hotwire procedure has me baffled.
Thanks and this is going to be a fun project, just added cruise control to my '07 liftback last month and I've only had it for a month and a half. Also, I do NOT have an immobilizer so no big deal there. I DO have a manual transmission but that's easy enough to also jumper the clutch switch while remote starting (I don't really want to just bypass it out like others are suggesting)
Sounds like a fun project. I have been seriously fighting the urge to buy one of those TI watches, as I already have too many projects in the works.
To start the car, The gray wire in pin 5 of the keyswitch connector (which is the +12V via the AM2 fuse) has to get jumped to the Ignition and Ignition 2 wires and then to the starter wire.
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
JDM GROUND WIRE VOLTAGE STABILIZER TOYOTA YARIS jamal1984 Performance Modifications 17 03-26-2007 01:01 PM
