Old 08-25-2010, 10:52 PM   #12
Nebarnix
Nebarnix's Avatar
Sounds like a fun project. I have been seriously fighting the urge to buy one of those TI watches, as I already have too many projects in the works.
To start the car, The gray wire in pin 5 of the keyswitch connector (which is the +12V via the AM2 fuse) has to get jumped to the Ignition and Ignition 2 wires and then to the starter wire.
Ok, that's straight forward enough. In order to keep the ACC (mostly A/C!) on I am assuming that the 12V needs to stay connected to the ignition 1 and 2 wires? Or is that what the ACC wire is for (is it even possible to start the car without accessory power on?) Thanks for your help!
Nebarnix is offline   Reply With Quote
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
JDM GROUND WIRE VOLTAGE STABILIZER TOYOTA YARIS jamal1984 Performance Modifications 17 03-26-2007 01:01 PM
