Old 09-02-2010, 10:37 PM   #1
Hershey
forgot to mention that I opened that hood and reached behind the hot engine where it leaks and scooped some fresh oil on my finger tip and showed it to him . He wouldn't even look where the oil came from . Says " It's the head gasket and that's all I need to know " . Wonder if we should of left with the car and went to another TOYO service center ? Thing is , they would have to put dye in it again and go through the whole process again . No one seens to think that I know what I'm talking about . Taking more time and money ( gas ) . . What's your thoughts ? THANKS
Old 09-03-2010, 04:34 PM   #2
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
A. wouldn't need to put dye in again, it will still be traceable
B. Let him be a snot he isn't the one doing the work (you should have gone to the service DEPARTMENT mgr/similar manager, unless he gave you a card of his you probably were talking to the head service writer)
C. gas meter will not matter if they decide to run more tests, unless they empty the car, best advice is to take the car in with an almost empty tank, cuz they will more than likely have the car sitting somewhere idling with the a/c on at some point.
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Megan Axleback Gasket slothman86 DIY / Maintenance / Service 6 12-23-2009 09:00 PM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
Changing LED's In Projector Head Lights whooppee777 Cosmetic Modifications (Exterior/Interior) 16 03-01-2009 02:07 PM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
