![]() ![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
yaris checklist before going to al khobar
mga kayaris
pwede mag suggest kayo ng ipapacheck or iccheck sa sasakyan bago mag byahe sa al khobar? both jonimac and I are over 15K na sa yaris, but nagpasked kami ng check up / maintenance sa ALJ after eid holidays pa dahil daw sa dami ng naka sked, it would help alot kung may suggestions kayo, we're planning to 1. change the oil, and oil filter 2. replace air filter 3. top up brake fluids 4. spare tire and tools check 5. coolant level nu pa kaya mga kayaris? |
#2 | |
@syntax, I am planning to go to ALJ before the meet, so you mean 50/50 lang ang chances ko to have the service from them? Marami pa naman kailangan gawin kay mica like change oil, coolnt check, etc.
@ rye sabi samin ng maintenance or service advisor lahat daw ay kailangan may appointment, at may nakasabay kami na corolla na magpapacheck up ng 5K lang ay ganun din ang sinabi, ilan na ba kilometer reading ni mica?
@ jonimac most probable ay kailangan na natin i rotate ang tires ni minie at para mag adjust ulit ang suspensions sa pagrotate ng tires, tawag ka lang pre if you need help. |
@ jonimac most probable ay kailangan na natin i rotate ang tires ni minie at para mag adjust ulit ang suspensions sa pagrotate ng tires, tawag ka lang pre if you need help.[/QUOTE]
Thanks Bro, siguro sabay na natin patira kapag nagpa-change oil tayo dun sa mekaniko ni duke kamo, less pagod ba Kelan ba ito?
#6 | |
![]() ![]() ![]() ![]() Drives: 2010 Yaris YX Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Apr 2009
#8 | |
dun naman sa suki kong petromin ako nagpa change oil dati, suki na rin dahil may libre ako oil filter lagi wehehehe,
magkano kaya ang OEM air filter? |
![]() ![]() Drives: sedan yaris y Join Date: Feb 2010
salamat treb
Nag pa 5K service ako the other day ... the quote before Kermit gets in the workshop @ (Toyota) @ 9AM was SR. 120.00 ... when I collected Kermit @ 1pm ... naging SR. 96 na lang ... may isang invoice worth SR. 50 for labor charges na free ... guess ito yong adjustment sa break ... kasi nireklamo ko na pag nag full break ako may grinding sound sa harap ko (driver's side) ...
ate zsazsa, nagpunta ka lang sa toyota? hindi ka nagpa sked ng appointment?
Naman ... parang kotche ... as in Toyota Corolla GL ... Ganda Lang!
![]() In fairness, diva nabanggit ko na nasa kasukalan at pwet sila ng Rakah ... kaya kakaunti ang nagpupunta duon at Ramadan pa ... kaya lang nalusaw ako sa araw ... kasi naiwan si Kermit @ 9am then come back pa ako ng 1pm ... kaya super walk with faith in your heart ang lola mo under the sun ... bwisit ... ang tindi ng humid that day ... kaya tamang Aleck Bovick ang lola mo ... TAMPISAW sa PAWIS ...
ganun ba? indi kasi kami gaanong ka kagwapuhan ni jonimac kaya hindi naman nakaya ng GL nung nagpunta kami sa ALJ naseem, na turn down pa rin kami at kailangan magpa appointment muna then saka issked ang 15K check up ni minie at shadow.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 07:10 AM |
| Florida Yaris Meet! 6/23/2007! | Sabretooth | Southeast | 13 | 06-05-2007 07:46 PM |
