Old 09-06-2010, 06:16 PM   #1
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Did you test the actuator cracking pressure with a regulator? Think you may be overboosting? Or have a leak somewhere in one of your lines? Try to put a MBC and cap it off if that is the case if you can't find the issue. If you are dead set on a new wastegate, and it does the same thing,, you have an issue with how you set it up.
Old 09-06-2010, 09:36 PM   #2
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Going to remove acuator tomarrow and try to test with my compressor. Vaccume leak is unlikely. There is only a 3in piece of vac. line between turbo compressor housing and actuator and it is clamped on both ends. There is no MBC tapped in. A MBC can only raise boost pressure it can not lower it. Base boost pressure is decided by the spring force on the wastegate actuator.
pimp my yaris is offline   Reply With Quote
Under $2500 Turbo Kit w/Intercooler coming soon! cdydjded Forced Induction Forum 58 09-23-2007 02:02 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 01:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 02:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 02:10 PM
