Old 09-09-2010, 10:57 PM   #1
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Are you sure you can tune that with just the FIC?
I was sure an E-manage was a necessity when boosted... For reliability without a check-engine light...
Old 09-10-2010, 09:52 AM   #2
Focus_Sh1ft
Focus_Sh1ft's Avatar
Both are piggybacks that essentially can be used in the same ways (I believe the FIC may even have more functionality).
I've been driving around for about 2 weeks without a tune and see no reason to mess with timing and ignition, as the ECM handles that just fine. There may be some performance to gain by advancing timing, but that's a very grey area because the ECM is likely to try and work around it. Maybe in a couple months, and if I like my tuner, I'll mess around with those. For now, the only problem is really the air/fuel ratio. In all honesty, with 1ZZ injectors in and no tune, the AFR is still pretty safe right up to about 5 psi. Then it begins to get really lean. I've yet to experience any knocking running on 93 octance gas.
Also, running with a CEL isn't necessarily a bad thing. Not all CELs indicate a serious issue. Many of them are just the ECU's way of indicating something abnormal... And if you know what you're doing and why you're getting those CELs, it isn't really a big deal. Nonetheless, if I'm correct about the CELs I do currently have, a proper tune with MAF clamping included should sort them out anyways.
2manywheels, thanks a bunch for the PDFs.
Turbo kits!! djgab101 Forced Induction Forum 26 03-09-2015 03:24 PM
Turbo kit Brainstorming Gideon Forced Induction Forum 16 04-19-2009 12:54 AM
