Old 09-12-2010, 12:21 AM   #1
sleey0
Drives: 2008 Yaris LB
Where is that connector in you pic from? The inside/dash fuse box?
So all we have to do to get these to turn on with parkers is splice using a 3m quick tap 3 + 13 (along with the other steps you mention)?
This correct?
Dude, you are like a friggin manual on the Yaris. I think Toyo should hire you:p
sleey0 is offline   Reply With Quote
Old 09-12-2010, 01:30 AM   #2
This correct?
That's the headlight stalk connector (at the base of the headlight stalk, under the lower steering column cover).
Correct on the splice.
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Has anyone tried taping into the parking lights for fog light installation (safe?) YarisSedan DIY / Maintenance / Service 14 03-20-2010 05:49 AM
2009 HB fog light installation rbell DIY / Maintenance / Service 3 06-17-2009 10:16 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 09:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
