Old 09-12-2010, 10:41 AM   #1
vitz rs
Drives: Vitz RS turbo M
so, you're moving the intercooler because it obstructs your coilpacks?
do you remove your coilpacks every weekend or something?
Nop. It is not that.
1st of all, with a top mount you can't install strut bar.
2nd, when u want to do anything around the engine bay, you will have to remove lots of things. Even with normal servicing, i will need to pay more for labour.
Cheers.
vitz rs is offline   Reply With Quote
Old 09-13-2010, 05:50 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
Cheers.
1st of all, the strut bar on a yaris is useless
2nd, what normal servicing would require the removal of your top mount? oil change? don't think so.. spark plugs? good for 100,000 miles..
3rd of all, labor will be based on a book, written SPECIFICALLY for your car, and will include the labor/time required to remove the IC if required, to do the work. this means that even if you swap to a front mount, you're still going to get the top mount quote from a service tech, because that's what is in his book.
just give us the real reason you want a front mount and i'll quit harassing you (you want people to see it) lol
Old 09-14-2010, 05:31 AM   #3
vitz rs
Hmm.... Regarding the
1. Strut bar, I doubt it's useless as I used it on my last ride, it did improve handling somehow.
2. changing of spark plugs can be DIY, and of course cleaning the engine bay
will be easier. Besides, the temperature near equator is around 32-34 whole year through and that makes the engine bay real hot. Hence, with the top mount (no scoop or vent on bonnet), there's only hot air going into the engine.
3. Lastly, in Singapore, workshops don't charge according to the amount of work they carry out and not according to the book.
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
"Parmas" Motor Parmas Forced Induction Forum 511 12-01-2011 08:00 PM
WTB: Front License Plate Mount and OEM wheels/tires Snarf77 Willing to Buy by private party 3 07-23-2009 12:43 PM
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 03:12 PM
