Old 09-13-2010, 11:50 AM   #1
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
14" or 15"
When you purchased your Yaris, did it come with 14" or 15" tires? My Yaris came with 15" tires when I purchased it from Enterprise. On AmericasTire/Discount Tire they list 14" as the OEM size and 15" is listed as a plus size, however TireRack lists both 14" and 15" as OEM options.
Which size would be more fuel efficient with LRR tires?
KrazyDawg is offline   Reply With Quote
Old 09-13-2010, 11:54 AM   #2
hazzy
Drives: Yaris YR
Here in Australia we have three models
YR- came stock with 14"OEM's with a 1.3L Engine
YRS- 15" OEM i with 1.5L
YRX- YRS with a bodykit and other extras
hazzy is offline   Reply With Quote
Old 09-13-2010, 12:05 PM   #3
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
My 09 sedan came with 15" steelies OEM. I upgraded to 16" later though. I would think (as long as you don't add a lot of weight) that a larger wheel would be more efficient, allowing further distances to be crossed with less RPM.
Old 09-13-2010, 12:55 PM   #4
Not really. The part about the rpm's is only true if the tire is taller, meaning the outside diameter is more. This will also make your speedometer and odometer inaccurate, which will make your mileage calculations incorrect.
Old 09-13-2010, 01:05 PM   #5
47_MasoN_47
Wouldn't the overall OD increase with larger wheels though?
Old 09-14-2010, 07:10 PM   #6
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Also, the larger the wheels and tires are, the more extra force they will take to rotate, and this can add up to lower gas mileage.
I think the old thought that I have seen a ton is that for every added 1 lb on the edge of the tire, wheel, it is like 4 lbs above the suspension.
Colin Chapman disciple
Old 09-13-2010, 01:10 PM   #7
why?
why?'s Avatar
Drives: Yaris LB
Toyota dealers don't even have 14" wheels listed as ever coming on the Yaris. I think they only came on 2006 & 2007 Yari.
Old 09-14-2010, 01:36 AM   #8
.Kevin.
I ain't even mad
.Kevin.'s Avatar
pretty sure my stocks were 15 steels
Old 09-14-2010, 07:48 PM   #9
landrym28
3,300+ at one point.. >:(
landrym28's Avatar
Drives: 2010 Hatchback RS
My 07 sedan base model had 14". I think with the 08's and newer, the base models come with 15".
Old 09-14-2010, 07:54 PM   #10
M4One
Drives: 2007 Toyota Yaris Hatchback
I think it depends on the country and model. My 2007 Canadian Yaris hatch was 14" stock, but I think in the U.S. it might have been 15".
M4One is offline   Reply With Quote
Old 09-14-2010, 11:12 PM   #11
US models almost always got 15" wheels/tires...
canadian non-RS models came w/ 14's from 06 to early 08 models....
my 07 came w/ 14" steelies and 175-65-14's....about 3.5% shorter than 185-60-15's, btw
Old 09-14-2010, 11:52 PM   #12
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
Mine came with 14's.
chrisj is offline   Reply With Quote
Old 09-15-2010, 01:09 AM   #13
kimona
kimona's Avatar
Drives: 2014 White VITZ
I thought all US models came with 15" wheels as standard.
BTW, my car's speedo (with 185/60/15's) was innacurate right out of the box. Now, with the taller 205/50/16's the speedo is dead on, and the tripmeter is accurate right to the 10th of a mile.
Old 09-15-2010, 02:52 AM   #14
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
15" in US, in other country they made it cheap so they use 14"
Red Horse is offline   Reply With Quote
Old 09-15-2010, 12:39 PM   #15
why?
why?'s Avatar
Drives: Yaris LB
I don't know if I call it cheap, I mean my 14"'s are definitely not cheap, and I am not the only one with them.
Old 09-15-2010, 05:35 PM   #16
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
OEM 14" steelies w/hubcaps on base model
Old 09-15-2010, 05:52 PM   #17
detroiter
detroiter's Avatar
Man that thing is low lol
Old 09-15-2010, 10:32 PM   #18
WTT: Yaris TS 15" for RS 15" IllusionX Canada 9 04-22-2010 10:57 AM
15" to 14" rims jambo101 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 02-25-2010 06:01 PM
WTB: Stock 15" Alloys, or 15" Alloys Betrivent Willing to Buy by private party 0 09-16-2009 11:42 PM
Does Toyota reset the speedo for the Yaris that have 14" and 15" rims? detroiter General Yaris / Vitz Discussion 19 05-17-2009 08:46 AM
ultra-light 14" or 15" wheels for Yaris 3dr leandro82 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 51 11-14-2006 02:07 AM
