Old 09-16-2010, 01:27 PM   #10
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by yaris2010RS View Post
i never thought of that...... y on earth would they give the dome a constant power? wasnt that basically the issue with the honda fit and the window switch catching on fire?
Because it's safer to run power to the light and ground it past the load. It makes it impossible to short out at the switch because you don't have a live wire.
The switch in the door-jam is simply a spring loaded contact that grounds against the body when you open the door, completing the circuit and turning on the light. (basically)
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
