Old 09-15-2010, 04:07 PM   #6
Originally Posted by yaris2010RS View Post
couldnt it be alot simplier? like could u not just pull the source of power (coming from the rear hatch switch) and connect it to the +12v side of the dome light?
The light always has power, it's the ground that gets switched.
You could have the hatch courtesy switch create the ground for the dome, but then you'd have to add an isolation diode to avoid popping the DOME fuse and you would have to snake wires through the headliner. It's much easier to work where the plastic pieces
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
