#217 | |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Without some clear cut pin-outs of which wires I need from the ECU it might be a little difficult for me ![]() EDIT: Ahh. I see you have a guide on the way. THANK YOU SOOOOO MUCH!!!!!
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats." xbgod - 9/23/2010 |
#218 |
Bathroom + Laptop = <3
eeeeek 2k i thought it was around $1200 ill have to recheck that thread
#219 |
I am sure he said $2k. maybe you are right.
He was going to cut a deal with someone here to test it out so he can get some more customers, but that was an exception. Regardless, I think that would be overkill for me. As long as focus put up that guide I will be fine:D
#220 | |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
#221 |
You guys ROCK!
Thanks!
#222 | |
THANKS! ![]() Oh, and I guess it is time for you to get tuned and see what that little supercharger can do! HA!
#223 |
C'est la vie
500$ for that boomslang harness is crazy unless your going to remove your turbo. And beleve me, once that turbo is on your only going to want more boost. Just ask Garm! I installed the wiring shown above in about 4-5 hours with a soldering iron solder and shrink wrap. I would have been a lot shorter if I had the info above. I spent most of the time checking sensor wiring diagrams in the toyota service manual. And then rechecking. And then sometimes even checking a third time cause I was drinking LOL
#224 |
Hahaha. I think I'll leave the drinks when I do mine. Quik connects, FTW!
Too funny.... Yeah, $500 is a lot. But you just plug it in and your done in, what, 30 seconds? AND your OEM wiring isn't cut so if you want to put it back to stock to sell it or something it makes life way easier. It is rape for $500 but what are ya gonna do when there are no other options for a jumper harness? Looking at it now I will wire it myself. I thought there would be more wires looking at that FIC harness. There are like 100 wires hanging off that thing! EDIT: Can someone confirm that the Vitz RS e-manage harness is exact to our cars? I can get one of those for like $200 and just wire in the FIC!:D
#225 | |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
Oh and also, I assume you used those wires I listed for the cam and crank? I need to wire mine in still, but I'm guessing that's the correct wire combo. |
#226 |
Yeah, make sure those cam and crank pins are correct.
Wouldnt' want someone to wire it up and it be wrong. lol
#227 | |
C'est la vie
#228 |
I would sure like to see someone try the Boomslang at some point. Just to know the wiring is correct with it.
So fun to watch your builds come up, guys!
#229 |
C'est la vie
I set up a base map today. As it turned out it was very rich. About 10/1. Then I did some minor adjustments and I got my air/fuel ratio in the 11.5/12.7 range. I will still do some more adjustments. I am surprised at how well the stock injectors are doing at 7psi. This thing was very intimidating at first, but after playing around with it I think I'm getting the hang of it. I may have to clamp the mass air in the future as I can feel the transition from closed to open loop fueling.
#230 | |
#231 |
C'est la vie
To be honest, it would be a lot of typing. I think my fingers would cramp. If You would like PM me your phone # and I can walk U through it using my puter at the same time. Its not as bad as U think. Let me know when is best time to call as well.
#232 |
C'est la vie
Question for the boosted?????? What spark plugs should I be runing with boost? A NGK number would be helpful.
#233 | |
Here's NKG's website. The 5 is your heat range, so you need a 6 for one step colder. |
#234 |
Most here run heat 7.
I bough ik22's for my buil which are 22 (heat range 7)
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 02:02 PM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| ZPI soon to release their turbo kit | turboyaris | Forced Induction Forum | 10 | 04-26-2007 02:52 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
