Old 09-25-2010, 10:58 PM   #7
Originally Posted by Lil Abner View Post
I spent the day wiring up my alarm/remote start on my 09 LB. I used the information on the site, and the awesome PDF that CTScott put together. At the same time I wired some other things up, including my fog lights. There are 2 "problems" here.
1. I wired my fog switch to the parking lights, so the fogs can be on regardless of the headlights, but still off when all the lights are off. From the light socket, I t-tapped off pin 13, into the switch, then out to pin 3 to trigger the "factory" relay location. This works great.
However, the problem is from the alarm. The alarm is a Viper 5900. The alarm has a "Selectable Light Flash Output" to flash the parking lights when you lock/unlock the doors. My fogs are HID, so I can't allow my alarm to flash the parking lights, which would trigger the fog lights. So I did what the factory alarm did, and tied it into the hazards relay. This works great for the lock/unlock. BUT, when I auto-start the car, the alarm turns the selectable light output ON, which causes the hazards to flash. To be honest, I don't want my car running in the winter with the hazards flashing.
Suggestions? Is there a way to tap into JUST the running lights that won't trigger my fog wiring??
2. I designed up a neutral safety switch for my standard transmission. It's an IR optical circuit. Ideally, I don't need it always turned on. I thought the alarm had an output that would turn on before the remote start cycle, turning the optical system on, then triggering the "neutral safety switch" input, allowing a start. But I was wrong. Suggestions? Or am I stuck with it always on?
The optical circuit basically reads the position of the shifter. If it's in neutral, it triggers the "neutral safety switch" input on the alarm, and also bypasses the clutch pedal switch. But I only want it to do this during remote start, not daily driving.
Thanks ahead for suggestions.
Curt
You can use a diode to turn on the parking lights without the fogs. Cut the parking light wire. Connect the alarm parking light flash (-) wire to the harness end of the cut wire. Also connect the anode of a diode to that same point. Connect the cathode of the diode (the end with the stripe) to the connector end of the cut wire and also connect the fog light wire to that same point. The diode will allow the fogs to turn on with the headlight switch, but not with the alarm.
For the neutral safety circuit - Most remote starters turn the ignition on for a second before cranking, so theoretically you can just power it from the ignition switched power.
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
yaris alarm yaris2010RS General Yaris / Vitz Discussion 24 05-03-2011 06:31 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
Viper Alarm wiring help Taiyaki DIY / Maintenance / Service 4 06-01-2009 05:05 PM
help me with my annoying alarm! misteo In Car Entertainment + Electronics (audio / video / alarm) 1 10-21-2008 01:49 PM
