Old 06-01-2009, 08:52 AM   #1
Taiyaki
アキバ製
Taiyaki's Avatar
Viper Alarm wiring help
Ok so I have the A1 MES power door locks, and it seems to only have two wires (one to lock and one to unlock)
I currently have a Clifford alarm wired. The main harness from the clifford is the same as the viper but the Clifford door lock has two wires but the Viper has 7.
-Black/White: Dome light supervison input #87
-White/black: Lock #87a normally closed
-Green/black: Lock #30 common (output)
-Violet/black: lock #87 normally open (input)
-brownblack- unlock #87a normally closed
-Blue/Black: Unlock #30 common (output)
-Violet: Unlock #87 normally open (input)
How would I hook up the lock and unlock to my A1 MES power locks?
Also it says on the A1 MES kit to make sure that the wires must have a negative lock and unlock output pluses. Positive pluses will damage it
another question, I will only need the door lock harness and primay harness right? and of course the valet button, antenna, and LED.
I wont be needing the Immobilizer, or auxiliary right?
Old 06-01-2009, 09:29 AM   #2
Check out this link for the Door Actuator wiring info:
http://www.commandoalarms.com/doorlockactuators.pdf
You will only need the immobilizer output if your car has the engine immobilizer. My 09 does, but I believe it was part of the power package.
You don't need the Auxiliary, unless you want to be able to trigger something extra, like the rear window defroster (not very useful in Hawaii).
Old 06-01-2009, 04:34 PM   #3
Taiyaki
アキバ製
Taiyaki's Avatar
Yeah I dont have immobilizer.
Ok I dont know where the #86 goes on the viper.
I will need two SPDT relays for each door?
Lock/unlock relay
30:Lock/unlock wire from actuator
85:12 volt (straight to battery)
87:12 volt (staight to battery)
87a: Ground
86: This one I dont know where it goes on the viper alarm
Old 06-01-2009, 04:57 PM   #4
Lock/unlock relay
87a: Ground
OK. I finally found some info on the Viper, which makes this more clear. The model that you bought has built in relays for the door locks, so you don't need external ones. Now, the question is how did (or did) you wire the A1 lock actuators. How the wires above get connected will depend on that.
Old 06-01-2009, 05:05 PM   #5
Taiyaki
アキバ製
Taiyaki's Avatar
Oh yeah I bought the Viper 5002.
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
Help with Viper Alarm xb9rumble In Car Entertainment + Electronics (audio / video / alarm) 3 02-11-2009 02:18 PM
Viper Alarm install gwasabi DIY / Maintenance / Service 0 10-29-2008 03:54 PM
help me with my annoying alarm! misteo In Car Entertainment + Electronics (audio / video / alarm) 1 10-21-2008 01:49 PM
