Old 09-27-2010, 05:55 AM   #1
Originally Posted by silver_echo View Post
i have the EWD... i came to the same conclusion of the ignition switch...
this is the first time that i have been able to catch you and be a troll to you... just playfully though...
in the OP, it stated that the relay was already changed... problem still exists...
I saw that, but I still say it's the relay. How many times have you seen a dealer claim that they checked something, but they really did not or didn't properly do so?
Old 09-27-2010, 06:56 AM   #2
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
I actually never took my Yaris back to the dealer to have them do anything on it. Remember I ran out of warranty only after 3 months of buying the the car. I only know everyone at the dealer b'cuz of my high miles everyone knows my car and always look out for me every time I visit the parts dept, from managers to salesmen to technicians. I'm the only person that works on my car. I actually bought a new relay myself and replaced it myself and the problem still exists.
Yaris 500,000 miles in 6 years 9 months 3 weeks and 3 days and still going strong!!!
http://www.youtube.com/watch?v=YnTlNLz9Iqc
http://money.cnn.com/galleries/2010/...le_cars/5.html
http://www.subcompactculture.com/200...-miles-on.html
trini_per4mance is offline   Reply With Quote
Old 09-27-2010, 07:22 AM   #3
What's the part number of the relay you have in there now (just to verify that it is the correct relay)?
From there I would check the following:
1. Ignition Switch - Remove the connector from the key switch and with the key off, check continuity between pin 5 (where the gray wire connects to) and pin 7 (where the black wire connects to). Then, move the key to each position and recheck. There should only be continuity between those two pins when the key is held in the start position.
2. While you have that connector off, on the harness side, measure the voltage between the gray wire and the black wire. It should read 12V. If it reads 0V, then there is a short in the wiring. If it reads more than zero, but less than one volt, then the automatic cranking circuit in the ECM is bad. This is the circuit that allows you to just bump the key and then the starter cranks by itself until the car starts. If that is the issue, you can do either of two things - Replace the ECM, or simply eliminate the "bump" starting (which you can do by cutting one wire in the under hood fuse box).
Old 09-28-2010, 06:11 PM   #4
trini_per4mance
I'll definitely try this. I'll let u know how it works out. Thanx!
Old 09-16-2013, 12:23 PM   #5
elcam84
Drives: 08 Yaris
Stepdaughters 08 yaris has started the same symptoms when it's hot. Relay ign switch are good.
Which wire feeds the start relay from the ECM. Need to get it drivable then get a ECM and have it programmed later on.
Thanks
elcam84 is offline   Reply With Quote
Old 09-16-2013, 01:11 PM   #6
Thanks
The orange wire in pin 52 of the ECM connector C20 (the larger connector).
Pin 52 is located on the row closest to the center of the connector, on the side where many of the pins are unpopulated.
Old 09-16-2013, 04:20 PM   #7
elcam84
Drives: 08 Yaris
Attachment 51818
Thanks for the quick reply. Will work on it in the morning when it's cooler. Still 96* here. Does that wire run to one of the white connectors that plug into the fuse box as there are two orange ones there. Unfortunately I don't have a wiring diagram for the car.
Old 09-16-2013, 11:18 PM   #8
It does indeed. Connector CA1 is the one that is lifted in this picture and the orange wire between the brown and red is the orange one of interest.
Old 09-27-2010, 01:01 PM   #9
silver_echo
ekodrvr
silver_echo's Avatar
wait, the stealer does what they are supposed to?
i like this smiley...
silver_echo is offline   Reply With Quote
Old 09-27-2010, 02:50 PM   #10
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
they do it in my case. Of course, their are benefits to being 6'2" tall and looking like a mountain.
Colin Chapman disciple
Old 09-16-2013, 03:46 PM   #11
bairjo
LOL....For some reason I was waiting for someone to jump on that...nothing wrong with a little humor here.
bairjo is offline   Reply With Quote
Old 09-16-2013, 10:40 PM   #12
nookandcrannycar
Yep. Many of his posts crack me up. Another member has that quote from Thomas Paine "Arguing with a man who has renounced the use of reason is like administering medicine to the dead" as part of his signature, and for some reason that quote prompts me to think of why? debating someone of inferior wit.
Sqweek while shifting (MANUAL) dallas DIY / Maintenance / Service 43 09-01-2010 03:57 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
