Old 09-27-2010, 12:05 AM   #10
silver_echo
ekodrvr
silver_echo's Avatar
Originally Posted by vwtech View Post
get a schematic and see which wire is energized in the start position I bet you the ignition switch is the problem. maybe temporarily you could pull the starter relay after you start it to save your flywheel. if you could send me a wire diagram I could help alot more though.
i have the EWD... i came to the same conclusion of the ignition switch...
My bet is on the ST relay (in the under hood fuse panel). Pop it out, tap it on a hard surface, put it back in, and see if the issue stops. If so, replace the relay, as once the contacts start sticking, they will keep doing so.
this is the first time that i have been able to catch you and be a troll to you... just playfully though...
in the OP, it stated that the relay was already changed... problem still exists...
i like this smiley...
silver_echo is offline   Reply With Quote
Sqweek while shifting (MANUAL) dallas DIY / Maintenance / Service 43 09-01-2010 03:57 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 08:01 PM
