#19 |
you need these 23250 22040
#20 |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Let me clarify when I say the 1ZZ's are to big. In my car, with no correction from the AEM FIC, it runs very rich. You can see what Im talking about in my profile pics of my dyno. With that being said, of couse you can use the AEM FIC to correct that problem. But here is the issue, you would have to use 1 of the fuel maps based upon TPS sensor input to correct the fuel trim when not in boost & the MAP sensor which is built into the AEM FIC to correct the fuel trim while under boost. That get very complicated & you need to find a really good tuner for that. AEM even suggests to use only 1 fuel map if possible to simplify tunning.
With that being said, I suggest finding an injector that is between the stock one's (190cc) & the 1ZZ (220cc) to make tuning much easier. |
#21 |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
You can change injector size through AEM FIC software very easily and it will automatically change injector percentages throught the entire rpm and load range automatically based on the size of the injectors you are using. U dont need a seperate TPS map, but You do need to clamp the mass air so the factory ECM does not go into closed loop during boost conditions. The FIC will alter injector signals to correct levels with larger injectors even in closed loop when you are in vaccume conditions. This is how AEM recomends tuning with only one map. Its much easier and less confusing then two maps.
#22 |
![]() ![]() Drives: VITZ Join Date: Aug 2010
i am confuse what part number is the oem injector and what part number is the 1zzfe oem injector?
#23 | |
| 1zz injectors suit the S/C just fine | LtNoogie | Forced Induction Forum | 51 | 04-30-2016 10:11 AM |
| FS: 05 1zz t/b and injectors | OTA'sTOY | Items for Sale by private party | 4 | 06-03-2010 08:07 PM |
| 1ZZ Injectors on NA Setup | MGargano | Performance Modifications | 14 | 04-22-2010 01:02 AM |
| Exhaust Pipe Size (Tamaņo del tubo de escape) | carlosh | Central and South America | 11 | 08-02-2007 04:15 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
