School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
Found it, was hiding in the PDF file.
![]() I can't seem to find the instructions related to inserting the pins into the white D3 connector. I can see where the connector is (will make a better tutorial later for situations like mine), just want to deal with this two-pin or three-pin situation in my DIY (FYI, the clockspring and connector under the steering wheel both have three pins... And I have an early '07). Last edited by firemachine69; 09-29-2010 at 07:09 PM. |
#2 | |
To add the pins to D3: 1. Release the lock by prying it up with a small screwdriver (it only lifts about 0.5mm): Conn D3 - Release Lock.jpg 2. Insert the pin as shown: Conn D3 - Insert Pin.jpg |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| Just installed Rostra cruise... My experience | cfiimei | DIY / Maintenance / Service | 7 | 01-13-2009 12:09 AM |
