#1 | |
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
![]() ![]() ![]() ![]() ![]() I liked your first reason better. ![]() I figured as much. I'm perplexed as to how this thing works, I mean, internally to the ECU. How does it recognize the difference between on-off, set-resume with just one wire (ground doesn't count)?
#2 | |
The wire to the ECM is being looked at with respect to ground. The ECM measures the voltage drop on the pin, which varies from 12V (with no buttons pressed) down to 0V, when the on/off button is pressed. The resistors between the other switches produce voltage drops between the two end points. |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| Just installed Rostra cruise... My experience | cfiimei | DIY / Maintenance / Service | 7 | 01-13-2009 12:09 AM |
